Timing data in tech manuals
esv
Post by esv »
My book (Haynes) says the following:
Ignition timing
Static or idle w/ vacuum hose disconnected: 5 deg BTDC
Ignition advance
33 +/- 2 deg at 4360 RPM
I guess 33 deg advance means on crankshaft (but I can't be sure of that, can I?)
But main problem is; does it mean 33 deg total advance as measured on the flywheel at 4360 RPM (no vacuum), or the advance in addition to static timing, so that a measurement would read 33 + 5 = 38 deg BTDC?
Grateful for any comments.
alexander
Post by alexander »
i dont know the answer to your main question, but i can say that advance is ALWAYS quoted as crankshaft degrees. which is hardly surprising in view of the fact that the timing marks are on the crank pulley or flywheel.
regards
alexander.
esv
Very interesting article
Post by esv »
Found this by looking around. Perhaps interesting this community!
http://www.fordcentral.ca/tech.htm
alexander
Post by alexander »
good find! that is a very helpful little article.
alexander.
