I would appreciate a map to get an idea of what works for this engine...(MAP sensor if that helps)
THANKS
john
Triumph TR 5/6 map anyone?
6 cylinder map
Well here's one that i'm using fine but without any tuning so far.....
Engine Mfg: Triumph
Engine Code: TR250
Cylinders: 6
Displacement (cc): 2498cc
Rev Limit: ???
TPS or MAP: MAP
Boosted or Normally Aspirated: Normally Aspirated
If Boosted- max Pressure (KPa): -
Modifications: TR5 cylinder head, fast road cam, twin SU carbs , K&N filters, tubular exhaust manifold, 6 to 2 stainless system.
Chassis: Revington TR rear coil over shock conversion, adjustable dampers.
Notes: Megasquirt next??!
Engine Mfg: Triumph
Engine Code: TR250
Cylinders: 6
Rev Limit: ???
TPS or MAP: MAP
- TR250 +3 map2.mjlj
- (682 Bytes) Downloaded 917 times
