VR sensor installation problems
steve_c
Post by steve_c »
I have set up the sensor to be 90 degrees from the missing tooth. When I put on a timing light I look to be 1 tooth adrift i.e the timing mark on the pulley shows counterclockwise of the timing pointer by about 1 tooth (10 degrees) this is with 10 degrees set into the timing light. The odd thing is I have to dial in nearly 60 degrees to get the timing marks to line up. Is there something about the wasted spark system that upsets timing lights (Gunson with dial in-able advance)? I have wired up the plugs as per the coil block numbering i.e no. one plug to '1' no.2 plug to '2' etc. I presume this is correct? This is my second attempt at putting the sensor in and I'm getting very frustrated . The engine starts ok so I'm somewhere near! Maybe I need to make my teeth profile deeper. I've had the teeth machined into the pulley and have alrwady deepened the 'dips' with a Dremel. Maybe I need to take some more out.
luke6040
Post by luke6040 »
do you have an image of your wheel?
steve_c
Post by steve_c »
See my post below, 'EDIS running problems'
Details problems with my first attempt. I have ground out the 'dips' by about another 1mm.
luke6040
Post by luke6040 »
I have not got mine working yet but this how deep they are: http://s73.photobucket.com/albums/i229/ ... mview=grid . I notice you dont have any adjustment, are you sure the missing tooth is in the correct position?
steve_c
Post by steve_c »
I see you have machined your pulley to accept a trigger wheel. Maybe I should have done the same. I can't remove the pulley ow unless I take the engine out, but I can get a Dremel to it if I'm careful.
I've double checked the TDC position and have the sensor 9 teeth away from the notch give or take a fraction of a tooth. The sensor is 1 to 1.5mm away from the teeth. I have some adjustment in the sensor position. Will try again this evening.
luke6040
Post by luke6040 »
can you try getting the sensor closer that may get rid of/reduce the depth problem.
steve_c
Post by steve_c »
Moved the sensor as close as I dare. At least the timing marks are getting closer and vaguely at 10 degrees. Still some instability though. I'm now gringing some deeper groves into pulley. This could take some time and several Dremel grinding wheels!!
luke6040
Post by luke6040 »
how wel centred is the pully? When i put mine on the lath it was miles out.
steve_c
Post by steve_c »
It's centred to within about 0.5mm
luke6040
Post by luke6040 »
how did you get it that close?
steve_c
Post by steve_c »
I think the guy that did the machining for me must have centred it up. The tops of the teeth have certainly been machined so I imagine he centred it prior to cutting the teeth.
david jenkins
Post by david jenkins »
0.5mm is NOT concentric! If I was making a disc on my lathe I'd be trying to achieve 0.05mm, or better (0.05mm roughly equal to 1.5 thou, in inches)
luke6040
Post by luke6040 »
have you seen the mini pully on the end mine waay nearly 2mm out, by turning it down tho i have got it nearly spot on.
Not sure if that possible when cutting the grooves out of the original
steve_c
Post by steve_c »
I've just finished reprofiling the teeth on my pulley wheel. Now 3 to 4mm deep with a much squarer profile. There has been little improvement on the consistancy of the timing. Wandering about by 10 degrees or so. I have positioned the sensor so it's almost touching the pulley. I was expecting a solid 10 degree default timing. I'm somewhat disheartened by this. I will connect up the Megajolt control unit later this week to see if this makes any difference. I'm really running out of ideas as to why the timing is erratic, unless it is a duff EDIS unit. If things don't improve I'm tempted to get an Aldon distributor instead.
Haven't seen a picture of your trigger wheel yet, but a simple and safe approach is to emulate what the Ford engineers did for their OEM designs.
This is a Ford Escort trigger wheel adapted to a Toyota 4AG pulley. Note the depth and thickness of the teeth.
The timing should be rock solid at 10 degrees on EDIS alone- this indicates the EDIS module can accurately track the position of the crank shaft.
