edis 4 wiring
mini-sprite
edis 4 wiring
Post by mini-sprite »
Am i right in thinking that on an edis 4 plug the ground wire is No9 and is brown and No 8 is 12v switch feed and is black? Just me who is used to seeing a ground as black :oops:
Paul
KLAS
Post by KLAS »
yes, you are right.
its a bit confusing if you are, like me, used to british standart wire color coding.
but its worth the "trouble", belive me ;)
mini-sprite
Thanks for that :D
And the cable sheilding on the VR sensor and the pip/saw to MJLJ should all be grounded to the same place?
Paul
Patriq
Post by Patriq »
Yes, grounded at the same place.
mini-sprite
Thanks for the answers i can crack on now :D
Paul
