New guy on the scene with a difficult engine for Megajolting. In order to build up the tension I will do a bit of introduction first and save the questions for last
I have a Saab Sonett III for which I am gathering parts for an engine with quite a bit more power than stock. One of the more difficult things to build is an inlet manifold for two Weber 40 DCNFs. These were used by Saab for a short while on their rallycars in the early 70's, but sadly these manifolds do not fit under the bonnet of a Sonett. In order to fabricate one myself it would be very convenient to get rid of the dizzy and create more space at the rear side of the manifold. By chance I came across the Megajolt scene and decided to give it a try.
The Ford V4 Cologne engine that was used by Saab is a very difficult engine to convert; no crank pulley, but one on the balance shaft; this is gear driven 1:1 from the crank shaft so I will use the pulley anyway for attaching the trigger wheel (as long as the gear wheels and balance shaft bearings are ok it should give no timing distortion). In very close proximity of this pulley are the pullies of the cooling fan and the water pump, so the mounting of the VFR-sensor is a challenge by itself. There is no room for bolting a trigger wheel directly to the crank gear under the front plate or fabricating an extension and putting it outside; the balance pulley is in the way
For simplicity I aim at using the crank pulley for the sensoring, but if this won't work there is the option of using the flywheel. I have one that has been lightened and in the area where material has been removed I could drill 36-1 holes, neatly separated by 10º, and put in 35 small bolts, using the heads for sensing.
Now the questions:
1: What gives the firing signal in a trigger wheel, sensing a tooth or sensing nothing (the space in between)? I guess it is the teeth, but I'd rather be sure.
2: If it is the spaces in between that trigger the firing signal, should it be ok just to drill 36 holes and remove the steel between two of the holes to emulate the missing tooth?
3: Should the size of the "teeth" (in this case the bolts) grow when the distance from the centre point of rotation grows? I guess not, but as a newbie in this matter I might think along a very wrong track.
Thank you all in advance,
Alex
