Lead free solder
SteveA
Lead free solder
Post by SteveA »
Before I start assembly, a quick question. Not knowing the spec of the components, can anyone tell me whether they are suitable for assembly with lead free solder or do I need to get some non-RoHS compliant solder?
Lead free solder of course having a higher melting temperature, approx 350 deg C
Steve
Hi Steve,
Yes, you may use lead free solder for assembling the kit.
What brand/alloy solder are you planning to use?
SteveA
Post by SteveA »
I plan to use a rosin flux based solder made by Multicore, 99.3% Tin, 0.7% Copper Alloy. Normal type of stuff see use for surface mount compents.
More about it here http://uk.farnell.com/5090866/mechanica ... tid=130713
Steve
Dimbit
Post by Dimbit »
I'm always wary of using lead free solder in a high vibration environment. If you do use it, use it well. It might be wise to add some extra dampening/padding under the unit once in place. I've seen loads of faults caused by lead free solder cracking.
