Vacuum in MJ software and my physical guage different
pristic
Post by pristic »
Howdy,
When I am going down a hill - and lift off completely from throttle. My Speco guage (which is boost and vac in HG/m) shows 20 on the vac
The MJ software shows around 50 ... is there any way to set the load guage in MJ software to read in HG/m ?
Pete
Hi Pete,
The software does not currently have an option to switch the display gauge to inch/hg.
Kilopascals were selected to measure absolute pressure as it's one simple linear scale from vacuum to boost- not one that switches units when pressure transitions from vacuum to boost.
The use of Kilopascals is consistent throughout the system- the Load Bins on the ignition map, the trigger set-points for the user-defined outputs, the datalogging features, and of course the display gauges.
Hope this helps!
pristic
Post by pristic »
Thanks Brent - ill just keep my conversions handy ;)
Pete
Our turbocharged MR2 is the same way- basically has the exact same gauge. It's easy to display with a analog mechanical gauge in real life, but gives computer systems and people who write software all sorts of fits. :)
