hi
My specs :
1380 CC
286 kent cams
7 head ports with twin 40 mm dcoe
10,6 to 1
Thanks for your help.
A map for a first start with a 1380 cc with TPS
For first start up don't use MJLJ, just pull the plug out, it will run on the EDIS's built in limp mode.
When you've got it going the factory default map will get you going during run-in till you get it to a rolling road for a propper set up.
That's what I was told to do and is what I did with my 1293 Mini with forced induction. No problems.
first map tested. need to wait better days. Carbies don't like this winter weather. It will be difficult ... it's colder and colder now...
- 7ports.mjlj
- (797 Bytes) Downloaded 911 times
