shift light and led bulbs
could you use this kind of bulbs with multiples leds 12 V 5 w or 21w ?
Unclear about your question, but each user defined output, including the shift light output, can drive 500 mA.
See:
http://www.autosportlabs.net/MJLJ_V4_ve ... hift_Light
A larger load would require a relay.
Are you referring to the popular LED equivalent replacement bulbs? These bulbs will likely consume less power than 5W/21W respectively; best is to check their spec sheet or directly measure their current consumption.
Almost certainly the 5W replacement bulb will work fine; the 21W LED replacement may be directly drivable as well.
See:
It sounds like you want to use an LED bulb designed to replace an incandescent 5W bulb. The LED equivalent bulb will consume much less power than the 5W bulb. (an LED with 5W of power will blind you!)
In any case, the shift light output should drive a 5W incandescent bulb or the LED replacement equivalent.
take a look on this link
http://www.superbrightleds.com/tail-brake-turn.html
what 's your point of view about them ?
