EDIS8 firing sequence
alexander
Post by alexander »
hi. i am just completing the wiring for an EDIS8 installation.
regarding the firing sequence, i presume the the EDIS fires the coil outputs in the sequence they are named ie A,B,C,D, but i cant see where that is stated in the documentation.
can someone confirm that is the case?
regards
alexander.
Hi alexander,
That is correct- the EDIS-8 fires ABCDABCD and so on. You should be able to match that up to the firing sequence on the target engine.
alexander
Post by alexander »
brentp wrote:Hi alexander,
thanks, brent. i must say it is a bit more of a challenge working out which LT/HT cable goes where, when dealing with an EDIS8!
