Could you please offer me some advice on the following?
I bought a full megasquirt kit, relay board and stimulator a short while ago from Glen's Garage.
It looks as though I will not be running fuel injection on the car I intended to and will be going for edis ignition setup only. Is it easy enough for me to get the relevant parts to convert my board/kit to MegojoltLiteJr spec. If so what do I need and where can I get it? (UK resident)
Or should I assemble the Megasquirt as per the MegasquirtnEDIS config and just not run the fuelling side of things? I believe this Megajolt EDIS setup will give me more resolution on the ign table, is that correct? (Not keen on the lack of interpolation between load sites though
Any advice appreciated. Many thanks in advance
Dan
