ok ive read all the other problems similar to this and so far cant figure out why im getting it
powered up correctly, configurator is set to the right port(4) i am not using a usb adaptor im going straight from rj11 on the unit to rj45 on the laptop
any suggestions?
does it need the serial adapter to work properly?
another ''time out on cyliner count'' post
Re: another ''time out on cyliner count'' post
Do you really mean that - rj11 on unit to rj45 on laptop? The rj45 on a laptop is an ethernet networking connection - not what you want to be using at all.79lancer wrote:...im going straight from rj11 on the unit to rj45 on the laptop
any suggestions?
The normal cable is a 9-pin female D-type to rj11, where the D-type either:
- connects straight into the 9 pin male D-type serial port on the laptop
- connects into a 9 pin male D-type connector on the end of a USB adapter that then plugs into a USB port on the laptop.
Which type of cabling are you using? Did you make the cable yourself?
