I have an A series turbo mini using the last megajolt before the V4 using all the needed ford parts. I have just put my engine back together and had it driving fine last week. It was running rich but i seem to have sorted this by redoing my choke seals and resetting the fuel pressure.
The problem i have now is that i seem to be loosing my spark just as i come onto boost. The car revs ok when no boost is created.
I have checked to make sure i have power to the megajolt unit, edis and coil pack when it misfires which it has. I can see this as the timing light stops working. I have removed my Vr sensor and cleaned the plug out as well as checking the gap to the trigger wheel.
Ive cleaned and gapped all the plugs.
When the misfire occurs the megajolt software goes to 0 and the rev counter drops to zero. The car starts to run when the revs drop back down and will misfire again just as it comes back upto boost.
Does anybody have any ideas as im abit lost? Also is there any way of checking the coil pack, edis and Vr sensor with a multimeter?
I have removed my hardcut unit and set the rev limit to 10000rpm
Cheers Ron
Megajolt loosing spark!
Jump to
- Autosport Labs
- ↳ General Discussion
- ↳ News and Announcements
- ↳ New Project Suggestions
- CAN Devices
- ↳ ShiftX2
- ↳ AnalogX
- RaceCapture App
- ↳ RaceCapture App Operation and General Q&A
- ↳ RaceCapture App Bug Reporting / Feature Requests
- CAN bus and OBDII integration
- ↳ CAN mapping discussion
- ↳ OBDII PIDs discussion
- RaceCapture/Pro | RaceCapture/Apex | PodiumConnect
- ↳ RaceCapture/Pro introductions
- ↳ RaceCapture/Pro General Q&A
- ↳ Sensors
- ↳ Hardware and Installation
- ↳ Lua Scripting
- ↳ Telemetry
- ↳ Bug Reporting
- ↳ Feature Requests
- RaceCapture/Track
- ↳ RaceCapture/Track Introductions
- ↳ RaceCapture/Track Operation
- ↳ RaceCapture/Track Installation
- ↳ RaceCapture/Track Bug Reporting / Feature Requests
- Megajolt/E and Megajolt Lite Jr. (MJLJ)
- ↳ Ignition Map Library
- ↳ Powered by Megajolt Gallery
- ↳ Assembly
- ↳ Installation
- ↳ Operation
- ↳ Q&A
- ↳ Future Upgrades
- ↳ Bug Reporting
- ↳ Fixes/Patches/Updates
- ↳ Hard Rev Limiter
