4AGE map, stock cams, dellortho dhla40
vladimir
Post by vladimir »
Here is mine map and I dont now does it right becouse my car have some misfire at 2-3K RPM. Can somebody try to repair if now how :D
When I pull full trottile its go like crazy, if I pull trottle slow its has misfire and stop-go thing.
Eny sugestion?
4age maps.mjlj
(717 Bytes) Downloaded 1470 times
Post by NITROPIXIE »
i would suggest improving on your vr sensor mount initially. By the looks of it, it requires some structural strengthening
vladimir
Post by vladimir »
Thanks, lot of people tell me that and it's problem for shure. I will do today and put some stronger profile of steel and try to make some triangle from two bolts and VR sensor. i will lett you now how progress.
framis
More info needed
Post by framis »
Vlladimir. I have the same setup in a Locost seven. I am having backfiring when I let off the peddle. Plus slow acceleration. Can we talk johnehorton@yahoo.com I am in Phoenix AZ Can you send me the MAP in a PDF form. So I can compare it to the one I am using. What jetting did you use and where do you get Delorto parts.
Broke4speed
Post by Broke4speed »
I get all my Dellorto parts from www.dellorto.co.uk. Amazing service, quick shipping, and they've got EVERYTHING :D.
framis
Vladimir about 4AGE
Post by framis »
I found one problem. Fuel pressure on the side draft carbs is important. PLus they are racing carbs and not tractable for street use. They want to go from idle to high acceleration with very little mid range. I will go thru the MAP and see if I can make slight changers that can effect the midrange. If you note on acceleration, the indicator goes from high vacuum to very low, then recovers and upon deceleration goes back high. I might try lowering the advance at high deceleration to correct this.
framis
Vladimir on 4AGE MAP
Post by framis »
Hi Vladimir. I was never able to open the MAO. Can you resend it to me at john@hortontv.com in PDF form. I ain't good at computers. Thanks. Since I wrote I leaned out the carbs and now have a light brown tip on the electrode and grounds. I checked the lineup of the timing belt cam pulley's and marks. All line up. I checked the exhaust system and intake. No leaks. I am still getting some backfiring on letoff. I am thinking using the EDIS can cause some as it is wasted spark. John
