Launch control
merlin
Launch control
Post by merlin »
Hi brentp,
Would it be possible to some way use the switch input to control the hard drive rev limiter what I need is a way to hold the revs on a limiter wile a switch is pressed on the steering wheel and as soon as the switch is in the off state ( ie a push to make or push to brake type switch) the rev limit should return to normal is there a way to do this ?
Yes, you can do this using the 'option' switch input. The option switch will select between two on-controller ignition configurations on the fly. The configurations include the map, user output configuration and rev limiter settings. See our installation and operation guides for enabling this capability.
Let us know how it works out, and if it ends up being an effective form of launch control!
