1982 VW Rabbit w/ 10:1, 1.8 8v engine.
Broke4speed
Post by Broke4speed »
Here is what I've managed to put together so far. I've added a bit of resolution at the low end, to facilitate part-throttle tuning. I might add even more, depending on the results.
1.8_8v_base.mjlj
Neuspeed 256* cam, adjustable cam gear set to +4*, stock manifold/downpipe/exhaust, dual Dellorto DHLA40H carbs.
(801 Bytes) Downloaded 1214 times
Loki
Post by Loki »
Thanks for sharing!
I have a 1.8 in my 1982 rabbit, I'm running a corrado g60 head and cam and will be running dual dcoe40s My build is in progress, but this may help me get started on tuning when I do finish it sometime next year (fingers crossed.)
Please do share your results and I will do the same with my map once I get it all nailed down.
What did you do with your IM shaft? I will probably lighten mine, or even delete it if I can find a suitable electric oil pump.
What sort of jetting are you running in your deltoros?
-Loki
