can you use maps from the squrt
jpindy3
Post by jpindy3 »
hi there,im building a pinto turbo but i am useing dellorto turbo carbs rather than injection,so there for i got a mj,
so i had a look for amy pinto turbo maps i couldnt find any,but somone i know has a pinto turbo but he runs injection and a squrt,could i use one of his maps,i have a megajolt v3 and have the 3D software,
thanks jamie
Hi Jamie,
Yes you can; however, you will need to copy the data points over by hand- there is no automatic import mechanism. It should be a straightforward process- at worst, just time consuming.
