help with wiring
jpindy3
help with wiring
Post by jpindy3 »
hi there,
right out of the 4 progs i did only really want to use the rev limiter,
so what do i do with the ons in not using,leave them or go to earth???
also do i need any other parts for the soft rev limiter?????
thanks jamie
Hello Jamie,
If you are not using the 4 programmable outputs you can simply leave them disconnected.
For the built-in soft rev limiter you do not need any additional hardware. For setting the soft rev limit see this part of the Operation Guide:
http://www.autosportlabs.net/MJLJ_V4_Op ... figuration
Scroll down a bit to section 5.5.3 for a description on how the soft rev limiter works.
jpindy3
Post by jpindy3 »
ok thanks is that the same for the v3
Indeed, it is the same for the V3.
the equivalent V3 documentation can be found here:
http://www.autosportlabs.net/Megajolt_L ... ersion_3.x
