Where can I buy loom tape?
Oliver Sedlacek
Post by Oliver Sedlacek »
You can buy insulating tape everywhere, but where can I get the non-sticky stuff?
Do you mean the pressure sensitive vinyl type?
Elliott makes this type of tape:
http://www.egitape.com/
http://www.egitape.com/egi_AEW.pdf
Somewhat a speciality item- It's not for sale in many places.
You might get the same effect with the non-adhesive "self-fusing" silicone tape:
http://www.rescuetape.com
It's pretty cool stuff- good to have a roll or two in the toolbox.
david jenkins
Post by david jenkins »
Do you REALLY want to use that stuff? It's fine if you never want to make changes to the wiring, otherwise it's a total PITA.
I would recommend split convoluted tubing - very neat, if done properly, and very easy to fix or adjust the wiring if you need to.
Just my 2p's worth!
David
Oliver Sedlacek
I want stuff that isn't sticky
Gassed'58
Post by Gassed'58 »
Autosparks are well known in the classic car world and supply sundries too, try this link ( hope it works otherwise search " tape " )
http://www.autosparks.co.uk/advanced_se ... pe&x=9&y=8
Oliver Sedlacek
Thanks. They call it harness tape!
