hey all new to all this but reading a lot so picking it up slowly. i have a rebiult 3.9 efi hotwire type injection system in my defender (wasn't in there before) going great edis in and installed coil packs etc, the only trouble i have is the engine position for the ecu does it remain on the negative side of the distributor or can it be taken from an output on edis? of mjlj? i wanted to get rid of the distributor alltogether but if it has to stay then it has to stay... any help would be great....
cheers
chris
newby need a little advice rover 3.9 efi
Temporarily try using the tach output pin on the ECU, that's exactly the same as the EDIS' pin 11. That *should* works, as it's just a short to ground upon each ignition event, much like what the factory dizzy/coil connection shows. Failing that, leave the dizzy in place, just to give the ECU a signal
you could also use the diode trick at the coil packs.
http://www.autosportlabs.net/MJLJ_V4_ve ... back_pulse
if that doesn't work
The above works nicely - you just need four diodes (one for each coil) rather than two.NITROPIXIE wrote:you could also use the diode trick at the coil packs.
