installing a map
installing a map
okay this is a dumb question, but I'll ask anyway....I see a map I would like to use (DannyP your map is burnin) ..okay I copied it over to my desktop...now can I transfer it to my MJ in this format (like cut and paste) or do I enter the values manually....hey I'm still wet behind the ears
well either I'm good or just lucky...I found by closing my default window and opening the new map, and clicking write ignition toolbar it's now running on that map, then hit commit to flash... it now saved and running on that map....right? Hey when you get to my age and you do something right on the computer this stuff is fun
If you have several maps you can create a folder called Megajolt Maps for instance in My Documents and put them all in there.
Then open up the configurator screen, go File, Open, then navigate to your Megajolt Maps folder and you should find all your selection of Maps there. Click on one thenopen and it will appear on your screen. Then write and Flash it to commit it too your mjlj unit. Be sure to save the last if you have made any changes.
When ever you change part of a map then go File, Save As, then call it something that symbolises vehicle and date so its easy to reference.
Once you have opened or saved a map in the Megajolt Maps folder then your Configurator will always default to that folder so you wont have to find it again.
Hope this helps
Ryan
Hope this helps
Ryan
