Size triggerwheel
laroguz
Size triggerwheel
Post by laroguz »
If I make my own triggerwheel, is the diameter important?
regards
Wim
DannyP
Post by DannyP »
No. They have been small enough to be hidden in a distributor(with different sensor) and as big as a flywheel. What matters is that the teeth and the spaces are the same size. It should look as much like a square wave as possible, and don't forget to properly position the missing tooth. Mine used the OE Ford escort wheel, a little bigger than 5".
Post by NITROPIXIE »
No its not to an extent, neither is the size of tooth space to a degree.
What ever diameter size triggerwheel you go for try to aim to have a spacing of 1 to 1 with the teeth, but it doesn't have to be an exact 1 to 1 spacing.
What is important is that you get the teeth equal distance apart.
What sort of size were you thinking of??
