I am having trouble getting a set of plug wires that will fit the Accel EDIS type coil. I have their 140028 coil with "european" contacts rather than the Ford clip on type. Upon the advice of Accel tech support I bought their race wire set to make up the correct length wires for my car, the problem is in the clip that go into the coil towers are not compatible. I contacted Accel again and after a long consultation it was determined that they don't make a custom wire application for this type of coil. Can anyone suggest a source in the USA for a plug wire kit that will have the correct type coil end clips?
Again this coil requires an 8mm european type plug wire according to Accel and was listed as being suitable for a Ford Focus 1999 to 2004.
Accel EDIS coil & custom plug wires
