Zenerdiode on MJLJ V4
laroguz
Post by laroguz »
Hi there,
Can anyone explain to me how i should place the zenerdiode? In the MJLJ V4 kit assembly guide it is explained as "The silk-screened stripe on the PC board matches the diode's stripe". But what side is the silk screened stripe? Is it towards the outside of the board or towards the 16 pin right angle molex connector?
regards
Wim
Post by NITROPIXIE »
Does this help http://www.autosportlabs.net/MJLJ_V4_ki ... g_Voltages
You can see the strip faces the molex connector on the board. The stripe of the diode should be orientated the same way as the white strip on the board as can be seen next to the solder pad on D4.
Does this help??
