Rev limit vs Limp home
Craigorypeck
Post by Craigorypeck »
As my megajolt has a rev limit that is controlled using the +12v to coilpack does this mean if I ever have a problem with the unit my limp home mode will be cut off too?
DannyP
Post by DannyP »
The rev limiter should not affect limp home. If the Megajolt dies, the limiter won't limit is all. The limiter is a pass-through device, it passes voltage to your coil until the Megajolt tells it to not to.
Craigorypeck
I see.. So as long as there is a MJ connected, without even being powered up the limp home will still work.
Happy days, I thought there was a trade off. Even better then!!
DannyP
Post by DannyP »
You do have the rev-limit board slid in the Megajolt case, correct?
Craigorypeck
Aye, tis.
Works well too, big puff of unburned vapour out the pipe!
