Hi guys, im sure this has been covered before, but just wanted to check. (did a quick search didn find what i was after.)
Do i need resistive plugs for MJLJ??
im running them in a mini, i think ive used BPR6ES before.... anyone care to confirm? OR Champion / bosch numbers. (had to swap mine out before due to cracked one, now need some new replacments.)
Cheers Ross.
Spark plugs??
Hey
Yes you do need to use resistive plugs and by the part numbers of the plug you are using the correct ones. I'm pretty sure that the MPI mini uses the same plugs if you ever need to refer at a shop.
I'm not sure on the part numbers for Boschh or Champion sorry, but again just cross refence those used on an MPI mini.
You most definitely need resistor plugs, see the problems I had here
http://www.autosportlabs.org/viewtopic. ... ght=#12192
I have NKG BRP6ES the alternative is Champion RN9YCC
