Runtime error - Microsoft isual C ++ Runtime Library
rich201283
Post by rich201283 »
I connected upto the megajot configurator ok.
I ran the hypertermial command Via C and pressed S got no responce.
Now whenever i try to connect to the megajot configurator i get an error.
Does the firmware need re-flashing?
Runtime Error!
Program: ...les\Megajolt Lite Jr. Configurator v4.0.2\mjljConfig.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support theam for more information.
rich201283
i have took both chips out and still get the same error when opening the config software
Post by NITROPIXIE »
Hi Rich and welcome to the forum.
From what i can make out from your posts you have put the uln2003 and the processor chip in the wrong way round. Chances are you have damaged both of these chips.
Then you tried the hyperterminal test by taking the processor chip out, connecting pins 6 and 7 by a piece of wire, connect the mjlj to the computer and apply power to the unit. This should give you the results I think you were expecting.
Am i right so far??
The firmware shouldn't need reflashing. If your not getting any communication with the unit its a good sign the processor has been damaged. Are any of the traces on the board melted or look burnt/damaged?
Hi Rich,
On NITROPIXIE's point- did you put the processor in the ULN2003 socket, and the ULN2003 in the processor socket, or did you put them in the correct sockets, but flipped backwards?
The error in the software is definitely abnormal. What version of windows are you running? Can you install the configuration software on a different PC and try again?
How are you getting on with this Rich???
spandit
Post by spandit »
I get the exact same message but my MJLJ was a factory built one so if the chips are in wrong, it's not my fault
Just found this:
http://support.microsoft.com/kb/884538
Let's hope the Hotfix works!
Edit: no, it didn't. Still get the message and can't use the software. Bummed
Spandit,
Could you give us a brief description of your situation and what hardware you are currently using?? Then hopefully we can diagnose the fault for you.
Do you have another computer handy to test if required??
Ryan
spandit
Post by spandit »
Hi, Ryan,
I'm using a Panasonic CF-T5 running XP Pro SP3. The software installs and runs fine (not that it does much without the MJLJ attached) until I apply power to the MJLJ when it instantly gives me the error as mentioned. The hotfix that Microsoft referenced mentions libraries msvcrt.dll and msvcirt.dll and says the problem only occurs when the version is 7.0. I downloaded and replaced the libraries but to no avail (and had a major problem with the laptop that made it impossible to boot - managed to fix it by removing the HDD and plugging it into my Mac).
The only test machine I have is my Macbook but running XP Pro under Parallels is causing problems - it won't install any drivers for my USB/Serial converter, despite me downloading them. It's a DSE XH8290 (which was recognised and installed fine on the Panasonic).
I've tried it with versions 4.0.0 and 4.0.3 - I don't know what firmware is on my MJLJ but I bought it two weeks ago from Trigger-Wheels.
Personally I believe it to be a hardware issue with the USB adaptor or a software issue with the computers/usb adaptor drivers at this time.
If you can, try to get hold of a desktop PC (these normally have dedicated serial ports) to confidence test the megajolt to make sure it can communicate with something. This way you can rule the megajolt unit out and concentrate on getting your computer work.
Unfortunately I do not have much experience with usb adaptors as i have a dedicated usb on my old laptop.
spandit
Post by spandit »
Annoyingly, my desktop PC runs Linux. I think I'll try to borrow another Windows laptop to see if that makes a difference. The Panasonic belongs to my workplace anyway (shitty laptop it is too). Thinking of buying an MSI Wave U135 to run in-car software (I've got EFILive for the kit car and an OBDII cable for the tintops). That will be running Windows 7
spandit
Post by spandit »
Solved!
It was my power supply. Switched to a simple 9V battery & it works fine now!!!
