Vauxhall Vectra V6 Coil and MJLJ / EDIS
Has anyone used a Vauxhall V6 coil instead of the Ford one with Edis6 & MJLJ, trying to avoid the clip on leads, which will be £Many for my Jaguar 4.2
Experience is a fine teacher, but the fees are very high!
I'm using a pair of Vectra coils with EDIS8 so I don't see the v6 coil being much different.
I did measure the resistance of the GM coil and it was almost the same as the ford one.
If at first you don't succeed use a bigger hammer
'89 TVR 400SE V8 "Wedge", now Jolted see Powered By !
