Changing from MAP to TPS?
1380 frogeye
Post by 1380 frogeye »
I have recently fitted a Megajolt to my Frogeye, and took it to a rolling road to sort the mapping out, the tunner says I would be much better of with a TPS than the MAP I have as the vacuum is unstable, Is it posible to change my MAP version to TPS?
Cars should make drivers smile
Yes, this should help you:
http://www.autosportlabs.com/mjlj-conversion-p-53.html
Also, you may be able to make your MAP sensor reading more stable by following these techniques:
http://www.autosportlabs.net/MJLJ_V4_ve ... _.28TPS.29
1380 frogeye
Thanks for that, not shure my soldering is up to the job, so will persevere with the MAP, the cam is a kent 276 so should work ok looking at what others have working.
Martin
