A+ block board to 73.5mm
•Megajolt ignition system
•Twin HS4's
•ported and polished cylinder head 36mm inlet 31mm exhaust
center main strap
•Billet 286 kent cam and followers
•lightened steel flywheel and back plate
•orange clutch with upgraded friction plate
•1.5 high lift roller rockers
•swiftune Alloy Duplex vernier timing gear set
•swiftune double valve springs
•1300 GT con rods (balanced)
•wedged and balanced crankshaft
•straight cut 1:1 drop gears
•Straight cut gearbox with centre oil pick up pipe, well that one is on the wish list
Il add some more later got to go to work lol
[/img]
