Engine: 1275cc
Carb: HIF44
MAPs tried: KLAS' 1275 & Aldon Yellow
Hi All,
Have megajolt system installed, seems to be working ok, except no matter which map I run it always misfires and backfires. Have tried offsetting the advance angle by +/- 5 degrees as I though my wheel might be a few degrees out but still no luck..
Don't have access to a timing light at the moment to check if Megjolt is actually advancing ignition.. can get one tomorrow
Please see below pics of wheel/VR installation ...
First image shows vertical alignment of sensor vs wheel:
Second image shows placement of teeth while engine is at TDC (checked via flywheel mark in viewing hole):
There is less than 1mm gap between sensor and trigger wheel..
Does the sensor wheel alignment look ok?
Is there anything I can try to get rid of the misfire? It's driving horribly!
Tim in Australia.
