Only firring on 1 cylinder
K H
Post by K H »
hi i have just installed a megajolt on my a series mini but i think it is only firring on one cylinder sorry if this is in the wrong place
Post by NITROPIXIE »
Firstly take all plugs out and rest them on the block, then turn the car over and check for sparks on all plugs with everything connected.
How far through the installation are you?? Have you confirmed your getting 10 degrees in limp home mode yet????
Ryan
Also, it sounds like it's firing on only one side of the coil pack- check all of the connections between the EDIS module and coil pack, and make sure you have the correct firing order wired up on the ignition wires
