I saw a post here and one of the posts was from brent saying
Brent, can you, or anybody for that matter provide me some more info on this?For those that would like to do firmware mods, there's also the AUX input on the board (not tied to the molex connector). That feeds a pin on the processor which can be configured as an Analog or digital channel.
My thoughts are this: currently I have my MJLJ hooked up to my Arduino via serial and I'm able to read the data and display it on and LCD or whatever I choose to do. I am planning on using the Aux Input for oil temperature but I would love to be able to hook my O2 (lambda) sensor up to the MJLJ and then pass the info through serial to my Arduino. Since I'm using the MAP sensor, I would disconnect the TPS input pin in the molex connector, and jumper it internally.
I wouldn't do anything with the data on the MJLJ side, just pass through, it would help to simplify the wiring in my car.
Thanks so much
Eric
