However, in my quest for knowledge regarding the use of hall sensors, I found lots of info regarding using hall sensors with MegaSquirt.
The principle's the same... a known event happening at a specific time.
I'm not overly sure what other technologies are used to fire timing, so obviously the inclusion of
- VR sensor
Hall Sensor
The addition of hall sensor would mean that at least some OEM applications could be catered for, ie hall sensor in dizzy, on cam shaft (VW do both types not sure on other manufacturers)
Same with output to coil packs... allowing folks to use a greater choice of output mechanisms to fire the ignition.
I'd guess that most of it would be software based rather than hardware for both elements... but it's something to think about I suppose
If I'm talking a load of tsoh, feel free to say so
