Oddfire V6 PRV engine
lars
Post by lars »
Sorry to disturb you all.
and sorry if i spelled sometthing wrong.
but my question is :
does Megajolt lite work on an PRV engine oddfire V6
i have installed it with TPS
I know a guy also from denmark with a car similar to mine ,running with mega squirt, and it works.
but i am not sure its working on mine !
i have a steady idle but when i acceleraet the throtle, its beginning to misfire.
the problem could be my map, setup, wich is default right now.
i am very "green" into programming ang engin tuning.
does any know a setup i can use on this type engine.
Kind regards Lars
lars
Anyone?
Post by lars »
Tried or heard about :
Volvo V6
Peugeot/ Citroen V6
Renault V6
Engines running with megajoldt and ford EDIS and coilpacks.
My setup is megajolt Lite ang ford edis 6 and coilpack with 6 "plugs"
The PRV v6 should t be with "odd fire" spark, and i am not sure it works unless you take a V8 Edis setup, and block off two plugs. but as you might can read on my post´s i dont know much about engines....
Please help me
as i wrote i have a steady iddle but as soon it give a little throttle it starts to misfire ( i think )
how do i check the timing ?
