Hard rev limiter on megajolt/e
mini_mad69
Post by mini_mad69 »
Im having real trouble trying to get the hard limiter working on my megajolt/e.
I soldered in the board and got the car running, without trying to get the limiter working. I've been trying for the last couple of days, but im struggling to get it to work.
It's confusing to install the board into the unit as the guide is for the MJLJ v4, not the megajolt/e which is different.
Also im unsure where the wire goes from the unit itself, I understand it comes from the Pin on the plug, and goes to the centre pin of the coil pack.
But do I cut the existing wire from the coil pack? join onto it? Im unsure.
Could someone explain how to solder the board to the main board of the megajolt so I can check I've done this correctly, and then where the wire comes from the ECU to the coilpack?
CHeers in advance
Ben
EDIT: just to mention I understand the operation of it, the soft limiter is working well, but the car does push through it.
DannyP
Post by DannyP »
Your original power feed that went to the coilpack needs to go to the limiter. Then the "out" from the limiter goes to the center(on a Ford style) pin of the coilpack.
mini_mad69
Ok, I did that and it didn't run.
So something is wrong in my wiring of the limiter board. Does anyone have a clear diagram or picture of how it's soldered to the main board?
mini_mad69
Looking at the installation guide, it looks to me that the coil +12v that used to come from my fusebox and working fine, will now come from my megajolt unit unit.
So looking at this diagram. Image
The top left pin (coil power) and the pin 2 spaces over to the right (rev limit) will both go to the centre pin of the coilpack, and the 12v I was using for the coilpack before will not be used?
Am I right?
Hi Ben,
While the board is a different revision, the 4 connections on the megajolt/e board remain the same. You essentially wire in the 4 PC Board pads on the Megajolt/E to the matching pads on the hard rev limiter, then slide the Rev Limiter board into the top slot of the Megajolt/E case.
these 4 wires are:
+12v pad on Megajolt/E to +12V pad on Hard rev limiter
COIL_POWER pad on Megajolt/E to COIL_POWER pad on Hard rev limiter
GND pad on Megajolt/E to GND pad on Hard rev limiter
Trigger pad on Megajolt/E to Trigger on Hard rev limiter
After this, you connect the the coil pack's center power lead to the the external COIL_POWER pin on the Megajolt connector.
How did you have it wired up before?
bobclevenger
Post by bobclevenger »
Hi Brent,
So if we are using the latest boards we can just ignore the part of the posted instructions that say to cut a trace on the MJLJ board ?
Also, the instructions say to use #14 wire for the +12 VDC and the coil power connections, but the boards will only accept #18 wires; given the short runs if wired internally, is #18 sufficient?
...Bob
Which instruction are you referring to that has you 'cut a trace'?
Install the largest gauge wire you can- 14 might indeed be too big for the hole, but 16 or 18 will handle the coil current for that short distance, yes.
bobclevenger
brentp wrote:Which instruction are you referring to that has you 'cut a trace'?
From the "Hard Rev Limiter 1.2.0" page. The bottom of the page reads:
... Most ambitious: wire everything internally: Jumper GND connection to MJLJ GND;
Jumper +12V connection to MJLJ +12V (14 gauge wire);
Use a thicker gauge wire (14 gauge) for MJLJ +12V power, if necessary, as the +12v supply will supply current to the coil in addition to powering the MJLJ electronics;
Jumper trigger input to REV_LIMIT output on MJLJ board;
Cut the REV_LIMIT trace on the MJLJ board running from the ULN2003 to the REV_LIMIT connector pin. The REV_LIMIT pin will now be the new COIL power supply..
Connect the Rev limit COIL output to REV_LIMIT pin on MJLJ connector.
Emphasis added.
...Bob
trevil
Post by trevil »
I also found out that the howto is outdated, you dont cut anything on the newer versions. Just solder the wires.
Megajolt on 2.4 CHI engine :)
bobclevenger
Yeah, I tried it without cutting traces and it seems to work. I would have appreciated some feedback, though.
...Bob
Thanks for the reminder. We'll update the docs with notes on the latest version.
