Spark Plug Failures?
MKnight702
Post by MKnight702 »
Hi, I'm running Megajolt on a tuned 1275 A Series fairly succesfully, however, I keep developing a misfire on no 4 cylinder. Pop in new plugs and it's fine for a while but then starts to run rough. I will check what part number plugs but I believe they are the resistor ones. Anyone got any ideas or hints on what (and potentially how) to check?
Thanks.
FULMNTE
Post by FULMNTE »
When you get the misfire and disconnect the MJ, does it run ok on limp home mode?
1971 Monte Carlo, 454 HO, Tremec 5 Spd, Weiand 177 Supercharger
What do the spark plugs look like after it starts running rough?
MKnight702
FULMNTE wrote:When you get the misfire and disconnect the MJ, does it run ok on limp home mode?
Will try then report back.
brentp wrote:What do the spark plugs look like after it starts running rough?
A little sooty plus wet since there is no spark. I may be running rich but I have a session on a rolling road booked to have a look.
spandit
Post by spandit »
Try swapping plug/lead to a different cylinder (make sure you get the coil pack terminals right, though!) - if this cylinder then starts misfiring, you know the plug/lead is the problem.
Have you done a compression test on your engine?
MKnight702
Yep, tried swapping leads, new leads, new plugs, new coil pack. The misfire always comes back.
Compression is fine, having rebuilt the engine (twice, don't ask) in the last 4,500 miles.
