Upgrade from V2 to V3
boostedmini
Post by boostedmini »
Hi all,
My V2 MJJL has operated faultless since i installed 4+ years ago.
i am looking to upgrade to the new V3 kit.
can anyone give me good advise on the major benefits etc?
is the molex connector different? what about coil and CAS sensor do they require upgrade and connector changes or is the whole system a straight swap?
thanks
Grant
cng1
Post by cng1 »
The changes from Megajolt V2 to V3 to V4 revD and onto Megajolt/E aren't significant in terms of functionality. If you've got a system that works well then I'd stick with that.
www.trigger-wheels.com
essentially +1 on that.
The later versions improved a lot on ruggedness. If you're in a high vibration environment I would recommend gluing the chips down with a little bit of silicone adhesive at each end of the chip. Otherwise, you should be OK!
