Changing from tps to map
Craigorypeck
Post by Craigorypeck »
I supercharged my engine and need to run a MAP setup now. I know I can get the stand alone map sensor with 3 pin connector on it.. is it as simple as hooking the tps wires over??? I presume not?? what do I need to do?
Tried a search but there were so many results that are not related!
Many Thanks!
Craigorypeck
i found the MAP conversion on the products page.
What boost will the standard sensor handle? and can I leave the TPS bits inside the unit??
the map sensor measures up to about 21lbs of boost.
You can leave the TPS components in place; you will just need to disconnect the TPS sensor at the molex plug.
