getting a bad waveform
eds911915
Post by eds911915 »
iv bin comparing the waveform my vr sensor produces to some that people have posted in the archives and mine looks really bad the peaks and vallies are all waded up and i cant see the missing tooth. I cant post it because im using the origanal snap on vantage but it has alot of edis tests loaded in the software. however i ohmed out the sensor individually and im getting .358 k ohm at the edis module connector and the reading goes open when i disconnect the sensor. the sensor and wheel gap is set at the same thickness of a cd or dvd.
What symptoms do you have with the running engine?
eds911915
Post by eds911915 »
the type of driveability im getting is very weak spark. the engine wont run.
