LPG (Propane) and MJLJ 4cyl
LPG4DWIN
Post by LPG4DWIN »
OK, I have a MJLJ and Propane on my 94 Geo Prizm. I have been just using the cars original Distributor and have just advanced it as far as I can but tire of the constant getting out of the car to adjust it to where it has enough advance to provide sufficient power and economy. I want to be able to do this on the fly. SO I have a Running MJLJ on the car now. It is still all set to the factory preloaded timing positions. I am not sure how to change those setting to increase them? I am still a Noob with this and would really appreciate any suggestions or help. I want to achieve the best power/economy settings I can to run like it was on gasoilne. $4.00+ a gal for gas vs. $1.69 a gal for LPG. I commute 100 miles a day to work. Fuel Mileage is the goal here.
Thank you in advance.
Jason
The Megajolt configuration software lets you tune the ignition map to whatever you need for your application. See the operation guide here:
http://www.autosportlabs.net/MJLJ_V4_Operation_Guide
