connection megajolt t/e
mirouf
Post by mirouf »
hello, I am French, and translated by google translate, sorry.
I am in the process of mounting a mgjlt REV with a Peugeot 205 Rallye.
I do not have my pc connected by.
the mgjlt is allimenté and the green LED is lit
I'm using a USB adapter with the correct driver.
I renamed my USB port com1, com1 is selected on mgjlt.
I got my port 115200b/sec cancel service and FIFO.
I use mgjlt v4.0.2
when mgjlt is disconnected, his mark "not cold open"
when mgjlt is connected, its brand "timeout reading cylinder count"
what to do?
thank you.
I am French
If you check Windows Device Manager, what do you see as the COM port?
You want to make sure the COM port in the software is the same as the COM port setting in Device Manager- see the instructions here:
http://www.autosportlabs.net/MJLJ_V4_Op ... erial_Port
mirouf
Post by mirouf »
yes, port com1 Windows Device Manager and port com1 mgjlt.
I read on this forum that many people had the same problem on and it was resolved by starting the engine. mgjlt this that the connected motor start up.
also a problem of USb port in the BIOS?
I am French
mirouf
Post by mirouf »
up :!:
I am French
Lazeum
Post by Lazeum »
Bonjour,
As-tu essayé de changer l'adapateur usb/serie si tu en utilises un? connais-tu quelqu'un qui aurait un MJ qui tourne? c'est l'info qui ressort le plus du forum.
Je n'ai pas encore branché mon MJ donc je ne peux pas beaucoup plus aider.
Je peux par contre t'aider si tu as des soucis en anglais ;)
maybe a different usb/serial adapater could help, this is most common asnwer we could see on the board.
I haven't played yet with MJ myself so I cannot really help much.
I can also help in translating French/English if that could be of any help ;)
Mathieu
mirouf
Post by mirouf »
non, c'est la seule chose que je n'est pas essayé de changé....
la voiture a effectué sont premier rallye ce week avec l'allumage d'origine, on va ce penché sur la mgjlt cette hiver.
merci.
I am French
Lazeum
Post by Lazeum »
Bien :)
D'ici là, j'aurais sans doute aussi ma version d'opérationnelle. J'en saurai aussi un peu plus.
Sur mon portable j'ai aussi une prise modem sur laquelle on peut brancher le cable qui va au MJLJ. As-tu essayé comme cela?
In English for those who might want to follow ;)
"No It's the only thing I did not try yet.
I run my first rally with stock dizzy, we'll that later during winter."
"I would have mine running also by then so I might be able to help.
Maybe you should try the RJ11 plug on your PC directly with MJLJ. No idea if it could work.
Mathieu
lebroussard
Post by lebroussard »
salut
j'ai le même problème
sur mon pc muni d'une prise rs232 la liaison fonctionne bien, mais je me vois mal avec la tour sous le bras pour les réglages dans le véhicule :D
sur mon pc je n'arrive pas à activer le port serie via l'adaptaeur usb, qui plus est je n'ai plus le driver d'origine.
tu as acheté ton adaptateur sur le shop de ce site?
si oui je veux bien un lien pour le driver
merci
a+
