Megajolt connection help
asbohotrodder
Post by asbohotrodder »
I have already posted this in the operation section so MODS if this is in wrng place - sorry.
I have a version 3 megajolt - I have wired the megajlt unit in as described and connected to PC - i cant get the computer to recognise the megajolt at all. i then re checked my wiring - and it seems ok - i put a test light on it - i definetly have 12 volts going in but if i put a light on the earth lead it doesnt light even with igniton turned on? should it or will it only do so here with the engine running? - basically i am wondering if the computer is not picking up the megajolt because it is not working or is it because of a connection prob between the computer and megajolt?? any help much appreciated. I am using a serial port lead not usb - this is driving me mad! thanks - Matt
Do you have the Megajolt connected to the engine, controlling ignition? If so, you can put a timing light to check if it's adjusting ignition advance while the engine is running.
Other than that, you can test it on the bench with a 9v battery into the unit. Make sure you are using the version 3.2.1 software, and ensure you have the COM port set correctly, according to the setting in device manager.
asbohotrodder
hi - yea it is connected to engine. Sorry for the stupid questions but new to this - i have version 3.2.1 installed.
i am now back off to garage to have a play see if can get it going - like i say i defo have 12v going in but doesnt appear to be much life from the earth wire with ignition turned on, or should this be the case?
i open device manager and it lists the 2 com ports but the device manager doesnt show which one is connected to the megajolt - sorry again for the stupid questions but this is driving me mad - thanks for your help.
asbohotrodder
still the same - got engine running but cant get computer to recognise it - tried both serial ports. now gonna put timing light on engine see what its doing but im not sure the unit is wrking because like i say i hd n life from the earth with ignition on? any ideas? thanks again
asbohotrodder
i have put a timing light on the engine and it is moving so the MJ is working - but i still cant get the computer to recognise it - any ideas folks? - thanks again
asbohotrodder
tried another computer and we are back in the game ;-)
Great! thank you for the update.
