Ignition cuts out intermittently
Booton
Post by Booton »
Hi
I've been running MJLv3 for a while with no problems. In the last couple of weeks the car has developed a problem where the ignition cuts out whilst driving along for a few seconds, stone dead for a bit followed by massive backfire once the exhaust sensor gets hold of the unburnt fuel then it comes back to life.
Most evident when cruising at 4000rpm (4 speed box) for a few mins. I have shift lights which don't come on so it's not hitting a false rev limit. AFR is good. Electronic tachometer connected to MJL flat lines when it does it. I have double checked connections.
Any help would be much appreciated
Cheers
Nick
cng1
Post by cng1 »
Check that your crank sensor mounting or trigger wheel hasn't got knocked slightly out of position. That sort of thing often manifests itself in the way that you describe.
www.trigger-wheels.com
Also, make sure your sensor bracket is extremely rigid. any excessive harmonic vibrations around a certain RPM will cause the system to misfire around that range.
Booton
Post by Booton »
Gents
Thanks for the replies. I've changed to a different bracket and so far so good, no further problems. Thanks for the great advice
Cheers
Nick
chris_1300
Post by chris_1300 »
I have exactly the same symptoms you describe, however, mine seems to be ok with the ignition retarded. Have you had any problems since?
