Megajolt installation
robinlittle
Post by robinlittle »
I am currently setting up a megajolt for a ford 302 v8 with the EDIS 8.
But I have setup on the bench with the trigger wheel turning in my lathe to simulate the input signal. but although I can read all the signals on my laptop with the software. I am getting a spark at all plugs but also seem to get a spark at all plugs when Megajolt unplugged and trigger wheel turning . Is this correct?
I did not expect to see this. All signal cables are screened.
Thanks in anticipation of your help
Cheer
I will post my wiring diagram if it will help
Hi Robinlittle,
Yes, this is expected. with the megajolt disconnected you will see a fixed timing of 10 degrees. this is the EDIS module's "limp home mode" when it cannot communicate with the ECU (in this case, the megajolt).
Hope this helps,
robinlittle
Thanks for that , guess it means my wiring is ok them LOL. Also looking for a base map for a ford 302 V8 until I get it on the dyno, can anyone help?
thanks RL
