Hello all. Got a quick question with regards to the Voltage Tables for the Auxiliary Input. I'm using my Auxiliary Input to monitor coolant temp, I've gone and measured the temp of the head at the thermostat to get a few points, then interpolated and extrapolated them to get the following series of numbers in degrees Fahrenheit, all working with the numbers in the voltage table:
1000
555
393
321
278
248
227
210
196
185
176
168
160
157
151
146
141
137
133
129
126
123
120
117
115
112
110
108
106
104
102
101
99
97
96
95
93
92
91
90
89
88
87
86
85
84
83
82
81
80
79
79
78
77
76
76
75
74
74
73
72
72
71
71
70
70
69
69
68
68
67
67
66
66
65
65
64
64
64
63
63
62
62
62
61
61
60
60
60
59
59
59
59
58
58
58
57
57
57
56
56
56
56
55
55
55
55
54
54
54
53
53
53
53
53
52
52
52
52
52
51
51
51
51
50
50
50
50
50
49
49
49
49
49
48
48
48
48
48
48
47
47
47
47
47
47
46
46
46
46
46
46
46
45
45
45
45
45
45
45
44
44
44
44
44
44
44
43
43
43
43
43
43
43
43
42
42
42
42
42
42
42
42
42
41
41
41
41
41
41
41
41
41
40
40
40
40
40
40
40
40
40
40
39
39
39
39
39
39
39
39
39
39
38
38
38
38
38
38
38
38
38
38
38
38
37
37
37
37
37
37
37
37
37
37
37
37
36
36
36
36
36
36
36
36
36
36
36
36
36
36
35
35
35
35
35
However, no matter what I do, when I restart the car I get a corrupted version, exported and shown below:
232
43
137
65
22
248
227
210
196
185
176
168
160
157
151
146
141
137
133
129
126
123
120
117
115
112
110
108
106
104
102
101
99
97
96
95
93
92
91
90
89
88
87
86
85
84
83
82
81
80
79
79
78
77
76
76
75
74
74
73
72
72
71
71
70
70
69
69
68
68
67
67
66
66
65
65
64
64
64
63
63
62
62
62
61
61
60
60
60
59
59
59
59
58
58
58
57
57
57
56
56
56
56
55
55
55
55
54
54
54
53
53
53
53
53
52
52
52
52
52
51
51
51
51
50
50
50
50
50
49
49
49
49
49
48
48
48
48
48
48
47
47
47
47
47
47
46
46
46
46
46
46
46
45
45
45
45
45
45
45
44
44
44
44
44
44
44
43
43
43
43
43
43
43
43
42
42
42
42
42
42
42
42
42
41
41
41
41
41
41
41
41
41
40
40
40
40
40
40
40
40
40
40
39
39
39
39
39
39
39
39
39
39
38
38
38
38
38
38
38
38
38
38
38
38
37
37
37
37
37
37
37
37
37
37
37
37
36
36
36
36
36
36
36
36
36
36
36
36
36
36
35
35
35
35
35
Sorry about the long list, the values aren't critical (I don't think), I've just posted them to show there's a clear difference.
I've done my best to follow the instructions in the V4 Installation Guide, but I feel like I'm missing something. My standard procedure is to 'Read Calibration' (in order to ensure it's all connected and reading), 'Load Calibration' (from my .txt file), then 'Write Calibration'. I don't get an option to 'Commit to Flash' when I leave the dialogue box, I'm not sure what else I should be doing, or why the list seems to be corrupted. Any tips would be appreciated.
Auxiliary Voltage Tables
Ok - figured out my problem. My problem is that I used the Fahrenheit scale. I used it in order to avoid using negative numbers. Thankfully, after checking everything, my lowest Celsius number is 1.
The Auxiliary Input Table won't accept values higher than 255. This is the reason why my last 5 values were random figures, which also impacted the rest of the table as they landed at random locations through the other values. I've had to change the last two figures in my new table (both were comfortably above 255), but the MegaJolt is now happy to accept the table.
