Ford EDIS4 Gen2 Coil pack Question
jonboylaw
Post by jonboylaw »
Can anyone please tell me when HT posts are common to each other on the Gen2 coil packs?
Does anyone have a schematic to share?
I would like to know how to connect it for a 1-4-3-2 firing order (VW T1 engine)
I have the posts labled from above:
3 2
-> [] To the EDIS
1 4
Cheers,
Jon
So all EDIS modules have the same wiring, so the conventional wiring diagram should work. If you have a cylinder synchronization misfire, it's quite easy to correct by swapping the coil pack outputs.
