Well, I took the RCP to the autocross the other day well the results were odd. Now I had run out of time so I was powering the unit via a USB cable which seemed to work ok. I had the GPS unit plugged in and on the roof and the sd card inserted.
The GPS seems to have just given me the same lat/long the entire time, I have Yaw readings and accelerometer readings that look just fine (log file 21 is a good example), even speed looks good.
Is it something that I'm doing wrong, or maybe a firmware issue?
Thanks! So far I really like it, I can't wait till it is fully functional and I can analyze my runs!
Is this a Layer 8 issue, or do I have a hardware issue?
- fast_five.zip
- A couple of runs at the autox
- (122.66 KiB) Downloaded 587 times
Oh hey, 20 and 21 look exactly right lol. 18 not sure it may have been when I was testing and using a bit of code that turned logging on when I was doing >10mph and off when it was not. I noticed you were on 1.1.7 and I was running 1.1.4. I upgraded to 1.1.6 and all looks good now! Before it would just show me a line that went from the top left to bottom right, or bottom left to top right for the gps view =). Very excited and glad it was nothing serious. Thanks Brent you rock!
