What IDE did u use for Race Analyzer? I wanted to contribute as an Engineer. I have tried CDT in Eclipse. Are you developing in Windows or Linux?
Source
Dependencies
I have the project (with GIT) in Eclipse CDT. And I am using the MinGW environment. I have installed the wxWidget-2.9.4 dependency and imported the gaugeWorks project (master branche). I also installed sqlite for Windows.
But I am keeping the Warnings:
- Invalid project path: Include path not found (C:\wxWidgets-2.9.4\msw-debug\lib\wx\include\msw-ansi-static-2.9). raceAnalyzer pathentry Path Entry Problem
- Invalid project path: Include path not found (sqlite). raceAnalyzer pathentry Path Entry Problem
- Invalid project path: Duplicate path entries found (/raceAnalyzer [Include path] isSystemInclude:true includePath:C:/Users/Ben/Documents/GitHub/RaceAnalyzer/include), path: [/raceAnalyzer]. raceAnalyzer pathentry Path Entry Problem
And errors:
- Program "make" not found in PATH raceAnalyzer C/C++ Problem
Description Resource Path Location Type
- Fatal error: wx/wx.h: No such file or directory StripChart.h /gaugeWorks/include line 12 C/C++ Problem
Do I have too build it myself? What could be the problem? Anyone had this before?
And errors:
Now that we just released the source we need to do a write up on how to get the development environment setup. Here's the short version for windows:
Dependencies:
wxWidgets 2.9.x
MinGW
MSYS
From the Autosport Labs github repo
The RaceAnalyzer project
The gaugeworks project
There are some hard coded paths in the RaceAnalyzer project we need to replace with environment variables.
We will follow up with a reply here when have additional instructions fleshed out!
Dependencies:
wxWidgets 2.9.x
MinGW
MSYS
I have problems in:
- AngularMeter.cpp
- steppedSpinCtrl.cpp
- lesStatusBar.cpp
20:38:56 **** Incremental Build of configuration MinGW-Release for project raceAnalyzer ****
make -j4 all
Building file: ../src/util/stringUtil.cpp
Building file: ../src/controls/ledStatusBar.cpp
Building file: ../src/controls/steppedSpinCtrl.cpp
Building file: ../src/raceCapture/raceCaptureConfig.cpp
Invoking: GCC C++ Compiler
g++ -DWX_PRECOMP -D__WXMSW__ -DNO_GCC_PRAGMA -I../include -I../include/comm -I../resource -I"C:\Users\Documents\GitHub\gaugeWorks\releases\release_1.0.0" -I"C:\Users\Documents\GitHub\gaugeWorks\releases\release_1.0.0\include" -IC:/wxWidgets-2.9.4/include -O2 -Wall -c -fmessage-length=0 -mthreads -MMD -MP -MF"src/util/stringUtil.d" -MT"src/util/stringUtil.d" -o "src/util/stringUtil.o" "../src/util/stringUtil.cpp"
g++ -DWX_PRECOMP -D__WXMSW__ -DNO_GCC_PRAGMA -I../include -I../include/comm -I../resource -I"C:\Users\Documents\GitHub\gaugeWorks\releases\release_1.0.0" -I"C:\Users\Documents\GitHub\gaugeWorks\releases\release_1.0.0\include" -IC:/wxWidgets-2.9.4/include -O2 -Wall -c -fmessage-length=0 -mthreads -MMD -MP -MF"src/controls/steppedSpinCtrl.d" -MT"src/controls/steppedSpinCtrl.d" -o "src/controls/steppedSpinCtrl.o" "../src/controls/steppedSpinCtrl.cpp"
g++ -DWX_PRECOMP -D__WXMSW__ -DNO_GCC_PRAGMA -I../include -I../include/comm -I../resource -I"C:\Users\Documents\GitHub\gaugeWorks\releases\release_1.0.0" -I"C:\Users\Documents\GitHub\gaugeWorks\releases\release_1.0.0\include" -IC:/wxWidgets-2.9.4/include -O2 -Wall -c -fmessage-length=0 -mthreads -MMD -MP -MF"src/controls/ledStatusBar.d" -MT"src/controls/ledStatusBar.d" -o "src/controls/ledStatusBar.o" "../src/controls/ledStatusBar.cpp"
In file included from C:/wxWidgets-2.9.4/include/wx/defs.h:28:0,
from C:/wxWidgets-2.9.4/include/wx/wxprec.h:13,
from ../include/util/stringUtil.h:10,
g++ -DWX_PRECOMP -D__WXMSW__ -DNO_GCC_PRAGMA -I../include -I../include/comm -I../resource -I"C:\Users\Documents\GitHub\gaugeWorks\releases\release_1.0.0" -I"C:\Users\Documents\GitHub\gaugeWorks\releases\release_1.0.0\include" -IC:/wxWidgets-2.9.4/include -O2 -Wall -c -fmessage-length=0 -mthreads -MMD -MP -MF"src/raceCapture/raceCaptureConfig.d" -MT"src/raceCapture/raceCaptureConfig.d" -o "src/raceCapture/raceCaptureConfig.o" "../src/raceCapture/raceCaptureConfig.cpp"
from ../src/util/stringUtil.cpp:1:
C:/wxWidgets-2.9.4/include/wx/platform.h:154:22: fatale fout: wx/setup.h: No such file or directory
compilation terminated.
make: *** [src/util/stringUtil.o] Error 1
make: *** Waiting for unfinished jobs....
from ../include/raceCapture/raceCaptureConfig.h:10,
from ../src/raceCapture/raceCaptureConfig.cpp:7:
Finished building: ../src/controls/ledStatusBar.cpp
make: *** [src/raceCapture/raceCaptureConfig.o] Error 1
Finished building: ../src/controls/steppedSpinCtrl.cpp
20:39:03 Build Finished (took 6s.316ms)
- AngularMeter.cpp
- lesStatusBar.cpp
make -j4 all
