Config. tach and MAP working, active cell doesn't track
bmcdaniel
Post by bmcdaniel »
Installed Megajolt in my 302 Ford Maverick. Ran it on the base map for about a week, now I'm trying to work out my own map. The software tach matches rpm with my in-dash tach and the load gauge seems to be working correctly but the active (green) cell in the table doesn't follow the rpm or load gauges. It stays in the low rpm / low load range and only provides the advance values in those cells.
bmcdaniel
Post by bmcdaniel »
I must have been doing something wrong. Comitted the map to flash and it's working fine now. A little more tweaking and I'll upload the map to the library. This thing is neat!
Glad you got it figured out!
